Originally I got this with Media Player Classic (last 4 versions at least) but I discovered it is occuring in Windows Media Player 11 as well!
What happens is it will play through a few files just fine and then suddenly crash with the above error upon loading (or attempted loading) of the next file. What the next file is changes each time and I can play that file again with no problem. In fact it never crashes on the same file twice in a row. I don't have to use a playlist either. If I keep the software open and click on the files in succession (opening in the same instance of the player), the same thing happens.
I already reformatted my hard drive with Windows XPSP2 and all updates. Not likely a codec issue like I thought it was since I haven't installed any codec packs. Also not likely a Media Player Classic issue since it's happening in Windows Media Player 11 as well. I swapped out the memory, still no change. I watched Task Manager memory & CPU usage during the process and saw no change at the time of the crash or leading up to it. Any other ideas?
Problem installing DVDGUI0948.exe
By ROGUTAH in forum Newbie / General discussionsReplies: 2Last Post: 12th Jan 2012, 19:17 -
QuickTime Player has encountered a problem and needs to close.
By DereX888 in forum Software PlayingReplies: 3Last Post: 19th May 2010, 16:16 -
mplex.exe has encountered a problem and needs to close
By mcv2008 in forum Newbie / General discussionsReplies: 4Last Post: 18th Aug 2008, 05:32 -
FAVC.exe Problem
By SilverDales in forum Video ConversionReplies: 2Last Post: 26th Jan 2008, 17:16 -
explorer.exe / drwtson32.exe keeps closing
By coolcoates in forum ComputerReplies: 7Last Post: 28th Nov 2007, 08:42
